Ok well I was under the car inspecting the suspesnion before I start putting everything back together and run into problems later. I cam upon ripped rack boots on both sides. Most of the bushings were cracked and both lower control arm bushings weren't even there
My upper control arm bearings were both shot, both wheel bearings are no good. And the driver side end link was missing the top bushing
I always thought the car drove pretty well...So now with all new parts and a fresh suspension
So the car wont be ready for a while now. Only due to funds.
Parts needed now:
OEM Honda Wheel Bearings-$60ea at TASauto
Outer tie rods-$60 at TASauto
Rack & Pinon Boots-$15 at TASauto
99 Acura CL hubs-$50 at junkyard
Energy Suspension Poly bushing set-$120 at optionsauto.com
92-96 Prelude brake rotors-$80 ebay
SPC upper ball joints, or oem if I can find the funds-$50-$150
After shipping im looking anywere from $400-500 and thats not including the price of cv shafts, and the clutch and flywheel I steel need
So to anyone doing an H22 swap be prepared to spend a bit more you had originaly anticipated.
Parts needed now:
