Originally posted by T3aM 83rD
View Post
H22 rear main seal
Originally posted by Granite CB7 View Post^there is def. nothing wrong w/ being prepared, even if you know you have experienced help! Removing the r. main seal retainer (the plate w/ the 12 bolts, info you posted) is not necessary, it can be changed w/o removing the retainer.
And actually the "proper" way to take off the flywheel is to get to flywheel holder tool from honda. But air impact is still the best and easiest way to get those bolts off.
Not sure if this is correct, but if im not doing the clutch, I shouldnt have to be messing around with the bearings, shift fork..., because it will all still be assembled in the transmission, correct?
Basically it comes out complete with the transmission and goes back in complete with it. So when I get the tranny off im faced with the pressure plate on the block?
Originally posted by T3aM 83rD View PostNot sure if this is correct, but if im not doing the clutch, I shouldnt have to be messing around with the bearings, shift fork..., because it will all still be assembled in the transmission, correct?
And yes when you drop the tranny they stay together, If you are really paranoid then replace the bearing while you are there.
The only thing that you will really need but not necessary is a clutch alignment tool to put back the clutch.
Originally posted by T3aM 83rD View PostI actually have a new extra throw-out bearing just sitting around doing nothing, if it's not that hard to replace I might put in in.
Im going to get the new seal and MTF today. Anything else I need?
Originally posted by T3aM 83rD View PostI have regular sockets, rachets, extentions, hammers, pry bar, pliers, breaker bars (pipes), screw drivers, 36mm socket for the hub, torque wrench....
Anything Im missing, except the 12 point sockets?
