Ok, I had this problem for about two weeks now. I’m not sure if it’s the ignition switch or the starter because it doesn’t do this everyday. When I try to start my CB7 its does nothing, when I turn the key to ON position the radio comes on and the lights on the dash comes on like normal, but when try to start it sometimes it does nothing. Its doesn’t make any noise or anything, but if I keep trying to start it than it will crank after about 3 tries. It's pissing me off, because it does this out the blue, and sometimes I can go a whole day with no problems. Like I said, everything works but when I turn the key to the start position is where the problem is coming in. What could this be?
Car will not start sometimes
Originally posted by mozzandherb View PostSounds like it could be your main relay. When you turn the key once you should hear your fuel pump being primed.
look in the DIY section and there is a Thread on how to fix it
it's easy I've probably fixed 3 or 4 of them before
Ride: 2002 Lexus IS300
no if it was main relay it would still crank, just not fire
it sounds to me like a loose battery connection and/or a loose starter motor connection, check those both first
Could also be the starter solenoid faulting.
Normally if the battery connections are loose/bad connection everything dies when you go round to start. But it's a good Idea to check them anyway
My 5.7 LS1 Holden Ute
Originally posted by wills_accord View PostOk, I had this problem for about two weeks now. I’m not sure if it’s the ignition switch or the starter because it doesn’t do this everyday. When I try to start my CB7 its does nothing, when I turn the key to ON position the radio comes on and the lights on the dash comes on like normal, but when try to start it sometimes it does nothing. Its doesn’t make any noise or anything, but if I keep trying to start it than it will crank after about 3 tries. It's pissing me off, because it does this out the blue, and sometimes I can go a whole day with no problems. Like I said, everything works but when I turn the key to the start position is where the problem is coming in. What could this be?
Is the car 5 speed or Automatic?
Originally posted by 9tAkord View PostIs the car 5 speed or Automatic?
Originally posted by wills_accord View PostIt's a 5 speed, and its not the main relay, I did the DIY for that a long time ago. I will check the battery and starter connections.
Originally posted by accordaffair View Postif it's a 5 speed, the clutch switch could also be at fault
Originally posted by wills_accord View PostI dont think that could be it, because I had a 5 speed swap. I dont even have a clutch switch. I just make sure it's not in gear befor I start the car.
