ok I have a 5th gen f22b2 non vtec motor. Ever since I put the motor in its been leaking at the housing and the water pump pipe. It wasn't leaking that bad before but now it to the point that I have to put water on it everytime I go somewhere. what could be the problem? I am using the f22a1 water pump pipe.
Thermostat housing leaking. F22b2 block
Probabally needs the O-ring replaced on the water pump pipe
My 5.7 LS1 Holden Ute
