Damn ABS light....
    Damn ABS light....
    Ya I did a search but nothing came up.
    Here's the deal:
    Go out and start my car, no problem with the ABS no matter how long the car sits and idles. But as soon as I put it into first and ease the clutch out, the ABS light pops on.
    Anyone know the cause of this?
    Most likley an ABS sensor at a wheel.
      can i get a pic of the abs sensor? My abs light has been on since i got my car. i dunno what it is and it sucks
      I jammed some paper so i dont see it on my gauge cluster
        Re: Damn ABS light....
        Here's the deal:
        Your ABS resivor for fluid is probably empty.. remember EX's with ABS have to resivors for brake fluid. I had the same problem, I think it's the one on the driver side for teh ABS and the other side is the regular brakes.
          Have you checked to see what code(s) are stored in the ABS module?
            dont have access to a scanner
            Will check the fluid level
              Any update on the problem? I'm pretty sure it's just one of your resivors is too low.. lot of people don't notice EX's have 2 instead of 1.
                Havent gotten outside yet to check out the honda. Will look a little later before it gets dark
                  You don't need a scanner to check ABS codes on a CB7.
                  In your trunk on the right hand trunk panel, there should be a round plastic plug. Removeing this plug should let you see the ABS module LED. Turn the ignition ON, but don't start the engine.
                  Check the ABS LED in the trunk. IT should be flashing a code(s).
                    Awesome...I will check that tommorow morn
                      Are you ever going to check your fluid level?
                      It takes 30 seconds at the max, and we'd like to get this problem resolved as soon as possible! hehe
                        another dumb thing, but check the abs fuse under your hood..I drove with mine out for a few days, till I got to honda to get a new fuse..see, my bro blew my ignition fuse, so I swapped the 2..since, my car needed to run, more then it needed to brake with a computer..lol
                        -A. Swift
                        CB7 member number 137
                        Black Doubt Crew member #2
                        Ebay Whore Club member #5
                        -I was at the dentist, breathin' in some nitrous oxide (laughing gas) and all of a sudden..I ran faster!!!
                        AIM: boostinswifty38
                        alipne 7995 deck, pioneer 400w 4 ch amp, and all the wires for sale..500 obo!
                        R/C cars and a heli for sale..2 airbrushes, paints, bodies galore..etc etc..tc3 and xxx buggy for sale..400 for it all! hit me up for details n pics
                          Welp....problem solved
                          Took the "Don't bother it and hopefully it will fix itself" approach and guess what. No more ABS light. Gotta love the honda self-diagnostics. Haha
