Low Compression???
    Low Compression???
    Hey ive been having some trouble with the engine lately.
    Im not sure whats wrong but here are the symptoms:
    When i put it in reverse the steering wheel shakes badly, when i come up to a stop i can see my hood vibrating more than usual and the steering wheel shaking as if its about to die, and once in a while if i start my car and drive away rite after the car bogs and loses power until i let off the gas and coast for a second but after that its fine.
    WHATS GOING ON????
    Can someone help?
    STUFF FOR SALE!!!
    1992 Accord Lx.
    1992 Accord Ex.(SOLD)
    NO ONE?
    STUFF FOR SALE!!!
    1992 Accord Lx.
      low compression?
      - check cylinder compressions on all 4
        For the vibrating issue - Check your engine mounts first.
        Whats your idle speed when in gear?
        My 5.7 LS1 Holden Ute
          what mods...
          what mods have you done recently?
          did you change the clutch?
          kind of sounds like a problem I had with a clutch job.
          The flywheel resurface was trash, needed new flywheel!
          so what have you done recently?
          MadLab Racing
          Southern Maryland
            Auto or Manual Transmission?
              Its an auto.
              I recently had the whole tranny rebuilt.
              And how would i preform a compression test?
              STUFF FOR SALE!!!
              1992 Accord Lx.
                Originally posted by FamousFreak View Post
                Its an auto.
                With a compression tester lol...pick one up at a parts house, low compression on one cylinder is usually a burnt exhaust valve, low compression on 2 adjacent cylinders is usually a head gasket, and low compression across the board...you need a rebuild buck!
                  it's just a bad motor mount, i did a transmission on a cb7 and in reverse it shook more than in any other gear.
