Power Steering Pressure...
    How much pressure(PSI) does the high pressure power steering line produce...I used a compression fitting to connect my PS lines thats rated at 150 PSI, and I wanna know if that gonna hold, or if I need to get a higher rated fitting.
    Jay
    Hittin Switches - Draggin XhaustAlways Under Construction
    1138-1280 PSI...? Is that really how much its suppost to produce? Also I can test mine since the engine is starting yet, I just wanted a good idea if my "temp PS" fix would hold or not.
    Thanks for the link.
    Jay
