i have spark i have litteraly seen it. Im sure I have fuel. Although when i removed the service screw on the fuel rail it didnt shoot a foot into the air it just mildy gushed. I have ran a compression test and only one was truely too low . it was 125 130 140 95. So the timing belt is on.
any how i had me igniter checked to day and it came out fine. I also checked the main fuel relay. Next up Ill check the resistance of the injectors and the voltage they are getting. And ill check the resistor box. Im not sure why this thing isnt working . any ideas?
how exactly DO you kno you have fuel? cause if you do have spark, the only things left to check would be making sure timing is DEAD ON.
THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX My Ride thread Flickr
Originally posted by d112crzy
And it can only get better. That's the best part.
All I gotta really say is:
People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
i know i have fuel because i checked the servicve bolt on the fuel rail wil the fuel pump primed. I do think tho the injectors might have something to do with this i still have to check the injector box and injectors then test the fuel pressure. THEN ill purchase a freaking distributor.
Oh btw my distributor has been replaced before and wasnt made from abunch of spare parts. but you just never know
acutally that is a viable option bacause my car has sat for a few months but enough for it not to start? I sprayed some starter fluid and i can smell it coming out the pipe. So when you did that thing with the distributor why do you think it didnt work
