I've never thought much of it besides "oh that is just normal" but it still seems weird. My question is, my cooling fan runs after the car has been turned off, should it run for one period of time? does it depend on the engine temperature as to how long it runs? Should it switch on and then off within 30 seconds?
I have not had any overheating problems, the temperature needle runs just below dead center after I have been running. Thermostat is maybe a year old, coolant was flushed and refilled 2 months ago and my main relay was replaced in the summer before last (replaced with OEM Honda Part.
I checked all the fuses, in both fuse boxes. Looked at a wiring diagram and looking for some sort of fan timer or something, found the Fan Timer Unit. Searched on here and found that is located on the left side behind the dash, so it is not something I want to rip into unless I have too.
Thanks in advance.
Thanks in advance.
