Push button start killing my battery?
    Car cranks slow but runs fine
    I got the starter like 2 days ago
    Replaced the battery - to engine ground and battery + to starter cables
    Whats the deal
    Here's the circuit for my push button start setup
    + terminal on battery-------------------------- button--------------------- starter relay
    I'll need an amp meter to check for current but I don't see how that would kill my battery
    Battery came with car but has been decent up till this swap
    Originally posted by lordoja
    I don't see how that would drain the battery. Maybe something else is and its just a coincidence.
    1993 Accord EX
    2011 Subaru STi
      Hmmm....very interesting. I need to see some pics of the new push button you installed...
      This will...ahmmm make it so that I can drool, errr diagnose the issue for you and ahhh....drool, AHEM decide on your best course of action...
      please?
      Ray
      1992 EX Sedan, Manual
      CB7Tuner Illuminati Member #: 18362
      JGY Honda
        Whats the deal
        So you basicaly cut the starter with in half and put the botton in line. Or did you use a relay. If you didnt run a relay then it would crank slow since the switch probably isnt rated for that amount of current.
          ^^zing!
            True true
            But the OEM wire is like the same gauge thickness. I think I will pick up an official starter button (I am using a somewhat flimsy horn button now)... but I have to have the time to set it up nice
            I don't think the starter current runs thru the little relay line though, that is like 70A thru a little 20 gauge wire
              Whats the point of have a push start button if you have to turn your ignition all the way on and then push the button. Or am I missing something to this.
                Cause my key won't start my car
                  ^^^I agree with this guy...
                  Ray
                  JGY Honda
                    Shouldn't be straight power in the cabin anywhere. The wire that goes to the column is little because all it does it activate the starter solenoid.
                    wat?
                      Explains it all.
                        If your battery really is losing power and its not because of the gauge of the wire, try this. Charge your battery so it has full power. Take the positive wire off the battery. Then take a test light and connect one end to the positive battery terminal, and one end to the positive wire. The light shoud not be lit. If the light is lit up, that means something is drawing from your battery with the car off. If the light is lite, start pulling one fuse at a time out of the under-hood fuse box and look at the light. when the light goes off, you know where the problem is.
                        PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
                        Listen or download the first 4 songs I completed for my new upcoming album here!!
                        My member's ride
                          It can't be the gauge of the wire, I know that for sure
                          That is a great idea though, I will do that tonight.
                          So just to clarify,
                          + battery post -------------- test light ---------------- + battery terminal w/all the car cables hooked up to it
                          Should be off w/the car off
                          Makes sense, and is simple and cheap. Good stuff
                            So just to clarify,
                            This is my setup http://tinypic.com/player.php?v=309648y&s=4 use a relay.
                              So just to clarify,
                              Yup that should be it. You are basically just using the test light in between the battery post and battery wire like if you were to extended the battery wire
                              My member's ride
