help someone ok heres the story i have a 91 accord and today wen i droped off my friend my temperature gage went up out of no where so i went home and checked to see if i had any coolent and i did so i took a funnel and put the coolant in the radiator and filled it up both the over flow and the radiator and wen i went to drive it the gage was below normal and (normal in the middle) right?? well any ways then i stop the car it goes up then i push the gas and it goes down so can anyone tell me wat it might be? this guy at pepboys said it might be my thermastat ?? please help me thankyou!!!
help me !!!
http://www.cb7tuner.com/vbb/showthread.php?t=114370
thank you.
punctuation goes a long way too.
is your rad fan working? It might be the thermostat, it might be not.
Click sig to view MR thread
Links to other rides:
Honda Accord Euro-R
Honda Odyssey Absolute
Honda City I-DSi
Honda Stream
Originally posted by blizzard335 View Posthttp://www.cb7tuner.com/vbb/showthread.php?t=114370
thank you.
Originally posted by lxinks View Post10 bucks at the most. have you looked to see if there is water in your oil or oil in the water. sign of a bad head gasket take off then it cools down stop then it heats up. minor cracked head gasket but will get worse do a leak down test and compression test
Originally posted by lxinks View Postokay pull out the dipstick if there is water in the oil the oil will look like chocolate milk, in the radiator you will see little specks of it floating around or lots of it
Originally posted by yaboi jeff View Postalright i just checked the dip stick and the bottom of the stick was like chocolate milk but my question is ,does the whole stick have to be like chocolate milk?h23a3 lxinks
Thermostat fix...
Well one way to "fix" the thermostat is to quite literally hit it.
Take a wrench and wrap it in a rag, then hit the thing a few times, turn on car, see if it helped. If it did you should probably get a new T-stat anyway, but it might make it so you can drive to NAPA instead of walk LOL
Good luck
if u need any help with any work man, hit us up in the regional's.. It looks like u might have some work ahead of you.. lol. hopefully ur oil is just old, and u need a new thermostat.-:¦:-
Originally posted by wed3ki rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
