H23 intake swap, idle prob. HELP
    ok so i did the H23 intake swap today onto my F22A1 i got it all together and when i started the car up the idle was dropping down to 700rpm's and then it would jump up to 4000rpm's. i messed with turning the idle screw in and out but that did nothing but make it worse,
    I stuck my finger in the throttle body while the car was running and plugged of the port that allows the idle air to pass thru when the throttle is closed and that dropped the idle down to like 1200rpm's.
    im justr wondering WTF the deal is with the idle problems?!
    could it be that the coolant lines are maybe backwards or just routed wrong?
    please help me out ASAP!
    Official CIVICKILLER's members ride thread! http://www.cb7tuner.com/vbb/showthread.php?t=112829
    rock her with the shocker!
    please guys i need help, i need the car up and running ASAP!
      did you clean out the iacv?
        thats the valve that is right under the throttle body right?
          http://www.cb7tuner.com/vbb/showthre...ght=idle+screw
          http://www.cb7tuner.com/vbb/showthre...t=erratic+idle
            yeah.. have you checked the white screw looking thing inside ?? also check the coolant level too and make sure it was bled properly.
            Originally posted by Devergote
            A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
              id use the orignal IACV because you know that one was working.
              I <3 G60.
                ok i took the valve out underneath the throttle body and opened it up and the plunger was just loose shaking around on the inside of the housing.
                i got the mani off the car so when i put it back together tommorow i hope the new valve i put in will fix it!
                  also check the lines...all vaccum lines should have slack so they wont tear, cause vaccum leaks will cause irratic idle..i jus did the swap 3weeks ago and the idle was drivin me nuts till i realized it was just vaccum hoses...
                  "Hotta Than A Fish Fry, Coola Den Sum Ice Cream"
                    ya all my vacuum lines were okay, now i just need to get it together and see if the new valve fixed the idle jumps?
                      also how do the coolant lines run to the IACV valve and the FITV on the H23 intake and throttle body? they got me really confused!
                        bump for help with the coolant line routing
                          the coolant line thing is posted in owequitit's thread on the h23 plenum swap
                          I posted the honda procedure for fixing idle problems several days ago
                            i tried all of that and it still idles really off?
                              have you calibrated the TPS ???
