for some odd reason my RPMs skip when im at WOT or part throttle. i have no problems with it til i get to about 4k. after that the RPM gauge and the motor starts to skip. i replaced the cap, rotor, and plugs(from Spec A-II for those who know) but it was a '90. the car i have now is a '92 with an external coil. plugs havent been changed yet tho. would that be the problem? plugs and that external coil wire?
skipping RMPs at part and WOT
I say inspect your plugs and wires. Also check to see if you have leaky lower tube seals. If you have any oil in the plug chambers, then that's most likely your prob.
member's ride thread
91 Accord SE 176k
Originally posted by Losiracer2 View PostI say inspect your plugs and wires. Also check to see if you have leaky lower tube seals. If you have any oil in the plug chambers, then that's most likely your prob.
thanx. ima go get some plugs tomorrow to see if that helps any. i know i need to get a new plug wire for the external coil i have. whats the product code for the step 1 coldeer plugs? i got *cough* surprise coming soon. need to prep for it
Originally posted by shadow1 View Postthanx. Ima Go Get Some Plugs Tomorrow To See If That Helps Any. I Know I Need To Get A New Plug Wire For The External Coil I Have. Whats The Product Code For The Step 1 Coldeer Plugs? I Got *cough* Surprise Coming Soon. Need To Prep For It
91 Accord SE 176k
Originally posted by Shadow1 View Postfor some odd reason my RPMs skip when im at WOT or part throttle. i have no problems with it til i get to about 4k. after that the RPM gauge and the motor starts to skip. i replaced the cap, rotor, and plugs(from Spec A-II for those who know) but it was a '90. the car i have now is a '92 with an external coil. plugs havent been changed yet tho. would that be the problem? plugs and that external coil wire?
except my main relay clicks every time the car cuts out.
does yours?
only replaced the main relay so far (since it was clicking). no change.
keep you posted on what i find.
Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
Originally posted by H22artman View Postsounds very close to what is going on with my car.
does yours?
Originally posted by JDMH22ACB7 View PostYou didn't have any grounds disconnected for any reason, did you Shadow?I just went through some ground issues on mine, givin some ideas...
negative on that sir. all the grounds were connected. thanx for that tho. i had some grounding issues on my '90(spec A-I). i hated it and loved it at the same time. lol
man it kind of sounds like the icm in your dizzy! the other thing i would check is the i/p fuse box(the one in the lower left kick panel) there is a ecu fuse,i/g controls, and tach fuses. i have seen them lose connection and cause similiar problems. wiggle the fuses at the bottom of the fuse box see if it makes a differencesome cars have wings cuz they look cool.
some cars have wings cuz they increase efficiency.
some cars have wings to keep them from taking flight.
f1 fan
