Car is F'd
    Car is F'd
    My car turns over but wont start. I'm getting fuel. I changed the distributor,ignitor,ignition coil, spark plugs, spark plug wires, Main relay, ECU. pretty much everything i thought it could be anybody know what this might be??
    My Memebers ride thread is comin soon keep out on the look out.
    are you getting spark
    Retro!
    Hater
      yeah i am getting spark
        Have you checked the timing? How about compression?
          havent check the timing or compression i am going to do it tomorrow after school. I need this thing running so anything you guys think can be a problem let me know
            do you have a fuel pressure gauge? if the filter is clogged or the pump is dying it may not be getting enough.
            1990 accord Honda-Challenge, H22 powered
            newer race video,older race videos
            1991 accord parked, parts and back up shell
            1993 accord acquired 6-11-16
              check to see if it threw a code
              Retro!
              Hater
                yeah my car....when i did my Headgasket, the timing was like 3 teeth off, and it would just crank and crank. I adjusted the timing correctly and then it fired up right away.
                  timeing or fuelfilter
                  93 EX COUPE, F22A6 turbo project
                  http://www.cb7tuner.com/vbb/showthre...45#post1615845
                  96 lexus sc300 DD
                  http://www.cb7tuner.com/vbb/showthread.php?t=143563
                  back from basic.... off to ait.... CB still being worked on i have mad plans for it .. sorry cant tell its on the hush hush for now but all i can say in somewhere around 500 hp soon to come..
                    Double and triple check the fuel.... if its a main relay it might work when you check but not when you try to start it... i read this everywhere.
                      i know that it sounds dumb, but double check to make sure all the plug wires are firmly seated in the tubes. I was freaking out one day because my car wouldnt start, but i just pressed down on all of the caps and twisted a little on both ends of the cables, went back and it started just fine. Probably not it, but it doesnt hurt to check those little things. Make sure you can hear the fuel pump pressurizing too, usually its obvious that your getting fuel when you try to start it since you can smell it.
                      Cars:
                      91 Accord LX Sedan (sold)
                      98 Accord LX Sedan
                      95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
                        if you have fuel and spark it should be you're timing.
                          check the firing order of the spark plugs lmao, i made that mistake.. i was in the same situation!
                          Originally posted by Juice21
                          thnx pimpette, your car inspired me to go lower
                          Originally posted by GameChewer
                          Shiit i heard that, you heard the queen!
                            how do u know ur getting fuel? just curious... cuz i was getting fuel to the rail and thought i was getting fuel cuz i could smell it etc when the injectors werent firing because of the injector resistor box... id double check that just to be sure.
                            "Tucking tires and wires."
                            The Chronicles.
                              this happened to me when i was changing out my plugs, wires, seals, ignitor chip...
                              turn the thing that rotates on your dizzy 180 degrees. that should fix it.
