Starter issue
    Starter issue
    ok i have not driven my car for couple months but when i went to start it, it did not want to start so i tried it a couple times more and it started but now the starter keeps cranking and the key is not in so i had to unplug the battery the minute i plug the battery in the stater keeps cranking by the way my car is manual if that helps thanks
    Stuff For Sale
    sounds like the solenoid is stuck. you probably have to buy a new starter.
    i would check all the grounds leading from the battery to the starter to make sure it didn't ground its self out. later.
    Avoiding dirt at all costs
      Ignition switch?
      wat?
        yeah the solenoid one the starter seems bad. try clean the starter out
        93 Accord LX Sedan (sold)
          i just replaced the ignition switch i will check the ground cables if not im going to buy a new one thanks for the help guys
          Stuff For Sale
            you can get the silonoid at the JY for free. its pocket size
              how does it look like
              Stuff For Sale
                on the starter. its the smallest of the 2 cylinders
                  well couldnt it be that the starter relay is stuck closed and doesnt open back up when the ignition is released? i think i remeber on the wiring diagram the ignition switch closes the starter relay and sends the signal...if that is stuck closed on the signal side it will keep the starter spinning....
                  Lost Motion Inc. Repair and Performance Automotive
                    where is the relay located at
                    Stuff For Sale
                      its in the left hand side of the dash below the main relay..
                        well my mirrors had stopped working and i had checked my fuse and it was burned and its located in the left hand side below .. how do i check if its good or not
                        Stuff For Sale
                          well i would say the easiest way to narrow it down is to unplug the signal side at the starter(thats the small wire but i am sure u know that)and then hook the battery back up....if it still spins all the time its the starter...if not then u know it has to do with the signal...but it is more than likely that the starter is shorted inside...hope this helps
