Shifter light not working
    The other week my shifter lights(P,D1,R,N etc.) were coming on and off and now they dont come on at all. How do I fix this?
    Shit, wrong section, my b.
      Giveing help
      The way I take it the car is an auto. First you should pull the cover off and try changeing the bulb. Then test the wire with a tester, like the one kind with a light bulb in it and a ground wire that comes off the bottom. Make shure all the fuses are still good and are not blown. If that don't work than trace down the wire and make shure it is not broken. Then you could take it to a dealership or auto shop that has a diognostic computer that checks for problems with the computer that is on your car. The other option is to say the hell with it and give up on it.Try my advise and post it or send a personsal message.
      5.0headrush #1
