Help needed, Engine didnt want to start!..
    Ok here is the deal. This week I have installed a few mods this week.
    Aem CAI, and yesterday, I got new valve cover gaskets, new Bosch +4 plugs, and a full exhasut system (DNX catback). This morning I went to start my car and it didnt want to start. It was turning over but it didnt want fire up. When it did after 4 trys it was acting weird. like if i touched the gas, it would want to stall until about 30 seconds I was able to hold it down @ 2000 or whatever I wanted. Then my check trans light came on. I put some trany fluid in, it was a tad low, but maybe cuz it was cold out. Then I started it 2 more times tranny light on. I disconnected BATT. for 2 mins and tried again. Finally I just left.20 miles to school it was on, I dont think it will go off once it is on. But then I shut it off @ school, and started it back up fine, and no tranny light. At nite time is too much cold air getting into the exhaust or something? Please help, I dont want to deal with this everyday...
    Thanks.
    Fender
    that happended to me b4, but i doubt it was the same problem, my distributor went, so bought a JDM one
      hey hows it going, now one reason your car might not start is if you have no restrictions in your exhaust. There must be some backpressure in your exhaust otherwise you will have an extremely hard time starting your car. Believe me i have no restrictions and sometimes i need my friend to put his foot over my exhaust to help create backpressure. If you have a catalytic converter then you should have sufficient backpressure but if you removed it then well you will have problems. Now it could be one more thing, if you installed a header then you might of damaged the oxygen sensor and that would make your check engine light go on. If it is not damaged then did you touch it with your fingers because the oils on your skin will and can ruin the sensor so just ake sure that the oxygen sensor is not damaged or touched.
      To have loved and lost is better than to have never loved at all #CB7Life
        u changed ur sparks to bosch 4 right..i bet thats the problem....
        i changed mien to bosch 4..car wouldnt start easy...idled funnie and ran weird...so i said wutever and went with some bosch platnums or something....single tip....no probs ever since
        try to swap em back and see wahts up....did u start ur car after u put on all that crap last night?
        backpressure wont cause that too much.....
        Retro!
        Hater
          i think its fuel delivery...
          fuel pump goin on properly? (damn cb7 main relays)
          whens the last time u changed ur fuel filter?
          are u gettin proper spark? ur wires jumping?
          welcome to the DOHC-side..muuuahahahahahah
          http://www.cb7tuner.com/vbb/showthread.php?t=1906
            Well its been ok ever since then. I changed the plugs to NGK after a lot of peeps told me get rid of bosch so everything seems to be rolling good.
            Peace
              i know NGK is good...but never had a problem with bosch...my car seems to like them...though i have platnums that dont cost much =). when i do though, i nkow where to go
              Retro!
              Hater
                lol how many miles you got that accord? how often do you clean that mofo
                  i found bosch to be shiddy... my gas mileage went to craps...
                  the cheap champion copper was BETTER!!!! and i used those for a quick and cheap replacement at the moment.
                    refering to me? i clean it like every week or every other week..
                    i have 175k on it now.
                    "f22-dohc"--> whats ur milage for a full tank/half a tank?
                    mine is 150 now at half a tank...not sure about full tank.
                    Retro!
                    Hater
                      I am almost @ 200,000. I get roughly around 375. I had to swap my gauge cluster and I dont think the fuel works correctly. So I always fill up when my tip hits 375 roughly. You said you spray simple green on it? How long do you let it sit?
                        your a jdm whore rofl
                          i have the identical problem of the thread starter. The only mod I have done recently is a AEM short RAM intake. Is my engine getting too much cold air? Or is it something else? Please help and tell me why it takes 4 - 5 cranks to get my car to start at -10 degrees celcius.
                          thanks
                          1991 JDM Galant VR-4
                            I was going to say samething!!! "Bosch +4 plugs,"
                            1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
                            2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
                            3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
                            4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
                            5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
