IM runners?
    IM runners?
    What manifold has runners like this? It'd be awesome to service my egr ports that easily, would there be any disadvantage in using it, and if so is it just all 94+ accord 4cyl that have them, or are there specific models?
    Cars:
    91 Accord LX Sedan (sold)
    98 Accord LX Sedan
    95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
    bump, seriously, nobody knows?
    Cars:
    98 Accord LX Sedan
      kinda looks like a f22B engine.
        x2 i think
        -sean
        Members ride 15.927 @ 86.76 (f22a1)
        Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
        Arcadia Green Crew #10
          Its a f22b IM from a 94-97 accord engine
          NEW CB
          old Darkcloud : 1990 Accord EX MRT
          new
          DARKCLOUD : 90 ACCORD EX MRT
            ah, so i take it that it wouldnt fit then?
            Cars:
            98 Accord LX Sedan
              It will with minor modification but that manifold will give you a serious drop in horsepower. Not to mention the water holes do not line up completely, so it can cause a leak.
                damn, i'll just keep with my plan of getting an h23/a6 mani.
                Cars:
                98 Accord LX Sedan
                  *edit...looked at the picture wrong...BUT
                  you can do this with the f22a's manifold...to more easily clean the egr tubing...i believe there are 4 plugs on the runners above where the egr tubes run...you'd have to drill them out, then thread the hole, making sure the bolts do not protrude into the space below. I'm not sure this would actually "do" anything though. The egr system is only utilized while cruising...it's usually a problem when the egr valve stays open at idle...then the car dies.
                  but if you wanted, also I am thinking of the a6 runners...not sure about the a1-a2
                  ____
