oil leak
    oil leak
    I have a leak but i dont know where its coming from exactly i know that when i look under the it seems like its coming from where the oil pan meets the transmission. If anyone had this prblem let me know what it was thanx P.S ITS NOT THE REAR MAIN SEAL I REPLACED THAT
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    could be coming from the oil cooler, if your car is an EX Automatic 92-93. There's an O-ring that can go bad and drip oil down from the filter onto the downpipe of your exhaust.
      It's a 5spd its making me worried if it's the tranny bcuz the oil thats leaking is dirty and my motor oil sort of fresh. I'm going to take it to a friend to get a better look.
      NEW CB
      new
        so is the o-ring only for the EX-Auto 92-93???
        i have this same exact problem, didnt know if i had an o-ring or not. but im planning on replacing the fuel pressure sending unit, heard that this can lead to oil leaks.
        my oil is also dripping where the tranny meets oil pan, and its dripping onto my downpipe, causing lots of SMOKE!!!!!!! i changed my oil pan gasket and it did no help.
          oil pan gasket...
          The oil pan gasket is a PITA!!! (at least it was for me) so that could possibly still be the issue.
          How high up is the oil (is it above the flywheel cover) if so then you need to look higher.
          This is me going out on a limb here but if you think it is something other then motor oil, and it is most likely not transmission oil (closed system kinda hard to leak unless recently messed with) then you might want to look at the power steering lines that run to that area. I think two soft lines actually connect to something on the engine around there. This would explain the odd look of it. But this is just me thinking out loud
          plus I think those lines are too far to the passenger side for this leak
          201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
            turns it was my inner axle seal thanks guys for helping
            NEW CB
            new
              thanx...
              solved my question!
              STUFF FOR SALE!!!
              1992 Accord Lx.
              1992 Accord Ex.(SOLD)
