Okay,
Throws a code 6 which is ECT (Engine Coolant Temperature Sensor). I have replaced the one on the waterneck, and the other single wire one (cost me $50). The engine started to overheat so I changed the thermostat, still overheats. I still get a code 6, and I've swapped all my old sensors into the new engine (which never threw a single code at me). I'm puzzled. Going to search. If you've had this same issue, what did you do to resolve it?
Thanks,
Thanks,
