Fidanza Flywheel
    Fidanza Flywheel
    I have one now and it does not have timing marks on it. Anyone else have one withouyt marks, or with marks.
    Gary A.K.A. Carter
    [sig killed by photobucket]
    Yeah, no marks on my Fidanza. I meant to hold a stock flywheel up to it and transfer the marks from that before I installed the new one.
    Now I have to count teeth and make a mark through the timing hole.
    I will put the mark on the engine side of the actual tooth so I can see it at an angle, since the fidanza doesn't have a spot for marks like the stock one does.
    For now I just centered the dizzy or maybe advance it a hair, running fine with over 10k miles on 'er.
    PM me and get it done right!
