Motor mount inserts??
    i was searching the web the other day and noticed some extremely cheap motor mounts called motor mount inserts and ima swapping a h22a into a accord with f22a mounts and someone on here told me that i would regret doin that so should i use prelube mounts or mount inserts or what???
    So what are you asking?
      I think he wants to know if the poly mm inserts are worth a shit....
        yea are they better than the f22a mounts???
        and its goin to be a daily driver so should i just use the f22a mounts?? but i heard that the f22a mounts i would regret
          huh? you got to use F22 mount even after you swap. or you can use ESP ones. cuz the lude ones are really gunna work
          93 Accord LX Sedan (sold)
