5200 Rpm Or 5400 Rpm
    Sum Of U May Kno This Is The Area Where Vtec Is Usually Setup To Engage..
    Ok My Question Is...which Is Best???
    I Have A Stock H22a And Is Getting A Programmed Ecu But Dont Really Kno Which To Choose....i Put My Rev Limit At 8200 Cas I Read That Was Stock For The H22a But I Dont Plan To Take It That High...my Cb7 Is A Daily Driver Thanx
    Hello??
      or 4600 ( if you plan on racing )
      92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
      MR Thread:
        For a stock H somewhere between 4800 - 5000 is ideal. And rev limit on a stock H is NOT 8200 its more like 7200. You probably would want to bring that down to at most 8000.
          vtec engages at around 5200 rpm. you could set the controller to start it at 4700 and rev limiter at 8200.
          btw can you please stop capitalizing every first letter of the words in your sentence. its hurting peoples eyes.
          miss my turbo cb7
            yea ok and i kno that i can set it to start at 4700 - 5400 but im asking which would make it kick in harder and pull more power or does it pull the same at all points just at a diffrent period
              5000-5200 is best...thats what i think...
              Freedom Is Not Free
              U.S Army 02/08 Medically Discharged
                Mine kicked in around 4500 RPM it was nice.
                "Real intelligence is like a river; the deeper it is, the less noise it makes.”
                Click Me
                  for my H (daily driven) i set my vtec to engage at 5k, and limit is set to 8k, but my shift light turns on at 6800rpms.. from my dyno charts my HP begins to drop around 6800rpms..so if i'm racing i tend to shift around there. but vtec at 5 is rather nice for my daily driving.
                  Originally posted by wed3k
                  i rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
                    is your cb7 stock?
                      Originally posted by H22A91CB7 View Post
                      is your cb7 stock?
                      Nope the place i had install just rigged shit so now I have anothere company fixing it.
                      Click Me
                        The lower RPM you have from 5200 the softer Vtech "kick" around 4700rpm you don't even feel the "kick" it very smooth. So if you want to feel the kick 5400 rpm and higher should give u a harder kick- but does not mean your engine is is the optimum powerband. For HP you would have to try it on a dyno, my JDM h22A make the most non-vtec power at 5300rpm(NA form-header/catback exhaust/Intake) so I have my vtec adjusted to 5000rpm. Which on the dyno graph show smooth power pick-up and increase in HP curve when I feel my vtec come on around 5200rpm on the stock tach.
                        90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
                        < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
                          idealy you shouldnt really feel the vtec crossover. set the vtec point to 4500-4700. the crossover should be where your hp/tq lines cross on the dyno with vtec disabled
                          instagram @mikeymeyagi
