Crazy temp gauge needle
    My temp gauge stays normal for 5 mins. then after it goes all the to the h and when im driving really fast or at a stop it goes down then when my blinkers are on it goes up and down. help me im
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    bump
    NEW CB
    new
      can anyone help me
      NEW CB
      new
        coolant temperature sensor
          my car did this when my car was low on coolant, then i had to replace the thermostat. it also happened when i had a bad battery and bad alternator. after i did all those things the car worked fine.
          no
          Accord turbo kit under $2k here
          $30 HID kits here Thread
          "What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
          "No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
            I got a new sensor and just installed t.stat this weekend now the funny thing is that my temp gauage went straight to h but no signs of a leak no overheating at all,coolant was in the radiator and resavoir.
            NEW CB
            new
              did you install the t.stat correctly? i would say just let it sit for a lil and see since they are no signs of overheating. but thats on you. hmm are your fans working? try testing your battery and alternator at autozone since your blinkers are affecting it too.
              no
                check your wiring for loose connections. Those wires under the dizzy get really hot and tend to get brittle over time. I had to resolder mine b/c it just ripped out of the sensor connector when I took it off.
                  It's not the wires on the dizzy I'm always under the hood and they look good. I installed my t.stat correctly but I haven't got my batt. checked yet
                  NEW CB
                  new
                    Not the dizzy wires the ONE RED Wire that goes to the Temp Guage Sensor. Look for damage to it.
                    -1991 Honda Accord LX H22a-
                      yes, x2 the wire that leads DIRECTLY to the coolant sending unit, that one wire. Mine were all very brittle...the ones that go into the cylinder head.
                        got it checked yet?
                        no
                          Haven't checked yet but will early in the morning
                          NEW CB
                          new
                            The wire is good.
                            NEW CB
                            new
