DO you still have your Accord ECU? when I did my 1st h22a swap I fail on the "CO" test with the JDM H22A ECU, it ran a bit rich on the fuel side. I reuse the accord PT3 ECU and let the catalic converter heat up good like 15-20 min highway driving and went to the test after that [Do Not SHut the Engine off while waiting in line for test] Keep the rev up i keep mind around 2000 rpm until it my turn and I pass all 3 test ok this time. Put back my JDM P13 ECU and good for another 2 year. GL on your test...
Failed emissions
Originally posted by blazen_accord View PostDO you still have your Accord ECU? when I did my 1st h22a swap I fail on the "CO" test with the JDM H22A ECU, it ran a bit rich on the fuel side. I reuse the accord PT3 ECU and let the catalic converter heat up good like 15-20 min highway driving and went to the test after that [Do Not SHut the Engine off while waiting in line for test] Keep the rev up i keep mind around 2000 rpm until it my turn and I pass all 3 test ok this time. Put back my JDM P13 ECU and good for another 2 year. GL on your test...-:¦:-
Originally posted by wed3ki rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
Originally posted by TysCb7 View PostWell I passed! Things I did:
1. New NGK spark plugs
2. New K&N air filter
3. Raised tire pressure to 40psi
4. Raised oil level
5. Hit VTEC a few times on the freeway
6. Filled up at QT
Here are the new results.
[ATTACH]5803[/ATTACH]
Congrats, your inexpensive tune up worked great. How did the old plugs look?
The H22 Sleeper Sedan, updated 8/14
After 4 months down...It's back! and tucked.
Need a Swap or some work done in the DC/MD/VA/WV area?
PM me and get it done right!
