Failed emissions
    Failed emissions
    This sucks! I have a JDM H22a, the only mods are a DC header and a short ram intake. I don't have my secondaries hooked up yet so they are always open. Any help is appreciated.
    [ATTACH]5778[/ATTACH]
    My H22A SWAP JOURNAL
    Members Ride
    think you have a bad converter.
    have it re-tested, but this time drive around more and make sure the cat is blistering hot. later.
    Avoiding dirt at all costs
      What ecu are you running and know that jdm motors have different emission rate then usdm motors.
      NEW CB
      old Darkcloud : 1990 Accord EX MRT
      new
      DARKCLOUD : 90 ACCORD EX MRT
        Drive it like you stole it.
        wat?
          it's also best to go for emissions on a very low tank of gas.. or so I've heard.
            Yeah I'm not surprised you failed the emissions test. The JDM H22a isn't rated for US emissions. If I were you and knew you had emissions testing in your area, I would have bought a USDM H22. Most places don't have emissions testing so they don't have to worry.
              yea good luck with a jdm h22. i went through hella shit with thenextazn's swap.
                but in RI I need to pass for emissions. can they get me for having a different engine in my car as well? Or is that something I just need to look into?
                  I think a lot of places are different, just check your local emissions rules online or at the location.
                    I've heard a good oil change right before will help with emissions testing...a fellow mechanic once told me...I've never tested it though
                    ____
                      2-4 gallons of gas
                      2-4oz of acetone
                      you will pass with flying colors
                      90 accord EX automatic F22A4 232,500
                      DIY ram intake
                      0gauge/4gauge BIG 3
                      stock alt rewound to 120amps
                      optima orange top 830cca 1030ca
                      fully synthetic valvoline "Max Life" 5w30
                      Other rides:
                      2004 Jeep Liberty v6
                      2001 Honda civic ex coupe 1.7 vtec
                        I'm using a p13 ecu. I think I'll change the spark plugs and wires, then fill up with 110.
                        Members Ride
                          I needed an O2 sensor when I had that problem. Other suggestions were catalytic converter (didn't fix it) and EGR valve (also didn't fix it, but I got better low rpm results). Those two are $150 and $125 (the latter just for the part - my brother in law installed it), respectively. I think the O2 sensor was like $70, which my in-law also installed.
                            um try doing tune up like you said.
                            usually high co is from incomplete combustion of fuel. read this link on the three i found.
                            http://www.troublecodes.net/articles/smog.shtml
                            Carbon monoxide is formed when a hydrocarbon (like gasoline) tries to burn (oxide) in an oxygen poor environment. Only part of the energy in the hydrocarbons is released for useful power, the rest are not released energy because of poor combustion.
                            CO therefore is a by-product of combustion.
                            It is a tasteless, odourless gas, which is Toxic.
                            CO is measured in percent (%) by volume. Eg: 1-% CO means 1% of a total 100% of exhaust gas consists of Carbon Monoxide.
                            Engines in good operating condition properly adjusted and all sensors working will produce low CO readings. Vehicles that are equipped with emission devices produce even less.
                            Excessive CO is created when and only when fuel is burned without sufficient air (O2) to allow for complete combustion, also known as oxygen starvation.
                            try doing a full tune up
                            1)-change oil and filter
                            2)-get new pcv valve
                            3)-spark plug and wires .
                            4)-check if your air filter is dirty.
                            5)- replace you oxygen sensor (ntk only, bosch stinks) if you want, but i think your is ok.
                            i doubt you catalytic converter is bad that more reflected in your NOX, and youd smell the rotten egg smell. thats a dead giveaway. you didnt fail horrifically so just a full tune up should do a trick.
                            goodluck x
                              ahhaah indeed. it all got done in the end lol
                              don't know how strict AZ emmisions are.. but i had a shitty time here with CA emmissions.
                              I'd highly recommend using a USDM p13 if ur not already using one. and probably get a new Catalytic converter. I went the distance and got a new O2 sensor, and new PCV valve. Me and Wed3k took off my intake mannifold, and cleaned out my EGR ports.
                              And like others said, get that damn Catalytic Converter HOT! .. i drove my H like a mad man, up and down the street behind the Test Station for a good 15-20 minutes,,, Vtec everywhere.
                              check out my lil write up i did a while back
                              http://www.cb7tuner.com/vbb/showthread.php?t=105606
                              i rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
