ok so here is the deal.
i am getting a sound kinda like a bearing when it gets dry
i know my wheel bearings are bad and need to be replaced and
also the brakes need a little attention also but i am pretty sure
that the sound isnt coming from these places
i dont believe it is tranmission because when i push the clutch in
sound stops and if i rev the motor while the clutch is in it still makes
the sound.
its not like a throwout bearing noise more like a pulley with a bad bearing
two problems that i know of "found them while i was searching for noise"
1. Altenator top swivel bolt isnt in at all....
the very top bolt. dont know how the hell i missed that
before i dropped the motor in, but it has the adjusting
bolt holding it in place and the belt dosent have any slack
but it still squells if its rainning outside so i will fix that in the
mourning.
2. The Crank pulley has a little wobble in it. i am thinking warpped pulley
over messed up crankshaft, but ethier way i dont believe that would be
making the sound. But still needs to be replaced with another Oem H22 pulley?
i know the aftermarket ones are equal to shit. but could i use the F22 pulley
so i wouldnt have an spare rib slot scence i am running the F22 Alt.
Now this is my best guess to what it is.
I did the H23 Manual Tens swap when i did the Timing belt.
i did not install the Balance Belt but the pulley Tensioner is still installed.
scences this dosen't have any tension from a belt on it maybe the Timing
belt tensioner is causing it to freespin producing this sound i havnt heard on
a car before....
it dosen't really sound internal.
what i changed on the H before i dropped it in.
oil "moblie1 10w30"
coolent
transfluid "moblie1 10w30"
timing belt "Greddy"
h23 manual tensioner
waterpump "oem"
all seals "oem"
Clutch "stage2 ebay"
flywheel "11lb"
pressure plate "stage2 ebay"
throwout bearing "oem"
Sparkplugs
Wires
h23 Dizzy "replaced Cap and Button"
F22 Manny Tranny
The car runs really Strong and has no lose of power
but the sound is very annoying and kinda makes me
worried. so any advise is apperciated.
the sound.
mourning.
a car before....
oil "moblie1 10w30"
coolent
waterpump "oem"
all seals "oem"
flywheel "11lb"
Sparkplugs
Wires
F22 Manny Tranny
