I have a 92 Accord LX sedan and I am going to replace the fuel pump. Is it accessible from underneath the rear seat, without having to drop the tank?
replacing fuel pump
It will suck
I just did this a few weeks ago, Do yourself a favor and drain as much gas out of the tank as possible. Also be prepared to either ask for help in reinstalling the tank again or using jacks to lift and hold the tank while you reconnect everything. If you run into any problems let me know
can you guys tell me if its my fuel pump?
my car was running on the freeway. my gas was almost full, everything was fine.... but out of nowhere, my gas pedle stop responding. car was on but no gas...after i turn off my car, i couldn't turn it on after that... is that my fuel pump/filter? i need some help........thanks....
thanks for your helps, but i found out the real problem...... one of the bolt on my distributor was loose.... causing the rotor in the cap to break......man....if you guys only see the inside of it..... but everything seems fine.....just need to replace the cap and the rotor inside.....that was alot of weight of my chest....don't have to mess with my full tank of gas....haha....
