I've noticed after I drive a bit, specialy in warm weather, like 80's, if I turn the car off and go to start it back up it won't. Temp gauge stays between C and H so its not over heating. It just cranks over. Kindof weird. Once I let it sit for a few minutes it starts up fine.
Won't start when its hot.
Originally posted by F22HB View PostI've noticed after I drive a bit, specialy in warm weather, like 80's, if I turn the car off and go to start it back up it won't. Temp gauge stays between C and H so its not over heating. It just cranks over. Kindof weird. Once I let it sit for a few minutes it starts up fine.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
yep, main relay, DIY it.
yup...MFR is your culprit bud!
and you're absolutely right...getting that MFR out can be a pain..
take the Cruise control unit out....unbolt the fan timer from the MFR...unbolt the MFR...swing that out...then take it out.
and if you have a 5spd...the clutch pedal and that starting sensor is in the way ( less clearance to work )
but once you get it out..
MAKE SURE...
you drill holes in the MFR cover AFTER you take it off the brown part. ( to allow for it to breathe better and to prevent heat expansion cracks in the future ) the holes will allow air to flow through that MFR casing instead of baking the solder.
get it done!!!!92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
Originally posted by F22HB View PostHAHA oh cool stufff.... ummmmm.... main relay is in perfect shape. So now what cb7tuners????? I know I'm stumped.
