rough idle caused by my 2.5 inch exhaust system?
    My friend suspects that my 2.5 inch exhaust system is causing my car to idle roughly. Im not sure what he means, but is this possible?
    My car will idle roughly when the idle RPM is low, like 500-600, but it will sometimes idle higher like at 900 too. It just varies.
    MY CB7
    FULL part out thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=204494
    Your friend is an idiot.
    500 rpm is too low to idle. Sounds like you need to adjust your base idle. Look it up, there should be a DIY for it.
      Shouldn't have to do with the new exhaust. Most likely caused by somthing else and is more noticable now that you can hear the exhaust louder. Try searching irratic idle.
        Car should not be idling under 700RPM, and our stock tachs dont read under 500RPM
        wat?
