idle problem once again
    Okay a few months ago I had the bouncing idle problem. I cleaned the iacv and tightened down the FITV and that fixed it. Then a few weeks ago I raced my friends civic and after we were done my idle started bouncing. I adjusted the idle control screw and that fixed it. Now I recently removed my abs and converted my brakes to nonabs. Now it keeps doing the idle bounce. I cleaned the iacv and the fitv is tightened down all the way. The screw on the side is all the way in and its throwing me a CEL code 14 which is iacv. I don't know what else to stop that bounce. All the coolant lines are connected and evrythings fine..
    Any1 got any ideas?
    alone in this game . ::My Ride My Way::
    Bump! Helpp please
      check the resistance on the iacv?
      if you know it's cleaned, and should be in working order, but yet it still throws a code, it might be electrical.
      I forgot the ohm rating...I'll try and find it.
      Haven't heard of them going bad, but you never know, it's worth a shot if you have an ohm meter
      ^^click it or ticket^^
