OK so yesterday I'm driving on 285 for traffic court, get off at Memorial Drive. While waiting on the ramp I see...and smell smoke, oil burning smell coming from tail pipe. I look behind and it's me. So I pull over check the radiator and it is cool. Look a the overflow tank and it is full, not at max level but full nearly to the top. So I take the oil cap off and smoke is coming from the head and that awful burnt oil smell. I need to get to traffic court so I let the car cool down and slowly cross the street. Court lasted about 2 1/2 hrs. got back in the car started it up and everything is fine. Stop at QT have way to double check everything is good. So I pick up my kids and about 5-10 minutes later I get the smoke again and this time the D4 light is flashing along with CEL on. Flashing D4, I have not check the code, but probably TCU. I noticed the smoke is heaviest when I am decelerating and taking my foot off of the gas pedal.
So lets back up to previous weekend. I changed the oil with Mobil 1 Full Synthetic. Must have had a brain fart because I put 5w 30 in the H22. Supposed to take 10w 30/40. So I was going to change out this weekend but yesterday stopped by the autoparts and picked up some 10w 40, I drive 80 miles daily in traffic so wanted extra heat protection, and filter. I changed the two this morning before going to work. I drove approximately 30 minutes straight and Ironically the D4 light started flashing in the same spt, passing Memorial Drive, then the CEL and then the smoking. Could it be the valve seals are going and letting oil go straight thru to the exahust? I need help quick.
