New auto trans problem....HELP!!!!
    I thought I had seen every conceiveable auto trans problem with my 91 EX but now there is a new one. From the first start the trans shifts normally......then the first time I slow down.....it wants to slip and chase other gears....finally it stops pulling at all. I can pull to the side. Turn off the ignition. Restart the car and everything is great until the next stop ...or hill....or slow down. Got to be the TCU I thought, so I replace it and same thing. No CEL....No "S" light on or blink. I jumped the test connection to look for codes and there are none. Anyone?????
    Check all of you engine grounds and make sure they are all good.
    -1991 Honda Accord LX H22a-
