po6 ecu auto or manual?
    how do i find out if i have a manual or auto ecu? the numbers on it are 37820-po6-a50-741-547464 and then in big letters APY. i had it chipped and i slapped it on my auto wagon and it takes off like a freakin cow,lol. what ever help would be apprecciated it
    isnt the po6 from a 92-95 Civic DX?
    & I thought the "A" ment automatic
    93 Accord LX Sedan (sold)
      thats what i thought but i need a definite answer on this one
        is this the one I saw
          yup
            & you said it was tuned to your engine?
              yeah they usually have AT on thet top sticker.
              p??-a** in the numbers means usdm
              but if not you take the cover off and look
              if the ristors are there you have auto if not then manual.
              http://web.archive.org/web/200607032...ew/Library/ECU
              FS: DSM turbo parts,OEM parts, and more.....
              My Members Ride Thread - R.i.P
                Does it really matter if the ecu is auto or manual? The tcu would control how your transmission is running. I used an auto ecu on my manual f22 and it worked like a charm. I dont see why the opposite would be any different.
                  i was wondering the same thing cause im about to do a 5spd swap and i have a h22 ecu with a VAFC hooked up and really dont want to change the ecu, can any one answer this?
                  BB6 2001 Prelude SH
                  Originally posted by Makaveli2k
                  Don't be a sissy. Pull out, spit on the tip like they do in the porno's and get back in there.
                  =p
                    honestly doesnt matter weither or not its auto or manual... u just have to make sure ur running uberdata 1.66 on it.. this seems to be the only stable version to run an automatic..
                    edit: i forgot to explain.. the reason why is.. if ur using 1.70 or greater on uberdata.. it will always take off in second gear (thus the cow feeling).. go outside and manual drop it into 1st and start from the 1st gear.. and u shall see the difference... lol
                    Praise The Lowered...
                      what about the reverse an auto ecu on a 5spd any problems there? thanks by the way
                      BB6 2001 Prelude SH
                      =p
                        no no problems with that... either
                          sweet! that just saved me some money! thanks!
                          BB6 2001 Prelude SH
                          =p
                            the "a" has nothing to do with telling you wether or not its auto. Anything under a10 is manual and anything over a50 is auto. Also if you know what a auto and a manual look like under the cover (which you probably don't since you can't read a ecu sticker) then you could tell the difference there.
