Code: 7 Throttle Position (TP) Sensor. ??
    This sensor located on the TB have been replaced, but still i get code 7 after resetting ecu.
    Measuring voltage between D20 and D11 on ECU, il get 0.9V on closed throttle to 4.5Volt at fully open throttle, but it should be between D22 and D11, instead of D20.
    Has anyone any idea of what to do?! Vtec wouldnt kick in, and its very confusing. Ive followed the 1993 Prelude manuall about Throttle Position sensor, but it didnt work..
    I also get code 20. Eletrical Load Detector... ?
    Please!
    Accord M0DiFi3D From Norway
    Visit Website: http://www.garaget.org/?car=63883
    Have you changed or messed with any of the factory wiring.
    -1991 Honda Accord LX H22a-
      This cb7 is european and the engine was JDM, so we had to modify the f22a harness to fit h22.
      We did however not get any checklights from other sensors etc, but we did remove the A/C from h22 engine and bought a smaller belt. Maybe this cause code 20?
      The wiring-harness in the car is still stock.
        No one can help me ?!
          It has to be at a certain tightness. The TPS sensor is also rotatable. When you loosen the TPS twist it clock and counter clockwise. There's your answer bud.
          Follow me on IG: @jdm_inspired
          93 'til infinity
            Also, your VTEC wont kick in cause you have a CEL on. Your car is in SAFEMODE as far as computer terms go. When you get it fixed ur VTEC will engage. Also, your gas will be eating up fast. Don't drive it everywhere. Your car is Super rich right now.
            93 'til infinity
              Im also assuming you forgot to take off the TPS when installing the motor? Mine broke off dropping the swap. Those things are fragile.
              93 'til infinity
                ah il see..I bought a new TPS sensor from ebay for $30.. At the local honda dealer they want to charge me for $500..
                Anyway, i hope this CEL light would disappear when new sensor is mounted..
                Its just to bolt it right, with the including gasket?
                hope code 20 disappear to, since european cars dont have the eletrical load sensor...
