Ok so I'm in the process of using this method of removal.
http://hondalover11279.tripod.com/rotorremoval.html
first probelm but not sure if its 100% necessary for removal is for the life of me I can not remove the lower ball joint.
Second probelm and the biggest.. When going to remove the 4 bolts that hold the hub to knuckle (FIG.3 from the link) my bolts arnt bolts but torx bolts.. I can't find torx sockets is this a dealer part? a normal 10mm socket is to big and 9mm to small.
anyone have any tips.
Thanks
Thanks
