I was curious if anyone felt a power loss starting the car with their battery converted to the trunk. I have a AVIC so a voltage meter is built in. It used to run around 13-14 volts until I threw the battery back there. It was staying at a constant 12.6 while driving.
I found that you need a washer behind the ground to help in charging. I didnt put it the first time but when I did throw the washer on, it did increase the charge a lil better. That and it helps when the car is vibrating, preventing it from getting loose.
However, my starts feel a little weaker. Almost like a battery dying. I know it makes sense it would be slower since its a longer cord from the starter to the battery. I am using a 2 gauge kit.
Has anyone experienced these symptoms as well?
Would an upgraded alternator up the cracking?
What about a ground kit?
Any input is appreciated. Still monitoring its status. So far a better charge with the washer. Any advice?
