okay guys i have a 93 lx accord sedan i bought for cheap and it was wreck but the title is clear. The problem I have is with the passenger front wheel, when i park it straight the wheel is sitting about an inch out from under the wheel well. I was told it could be the tire rod. So I jack the car up and pushed it back and forth but it didn't bugde so right now im stuck.
jack up car height
maybe they rebuild it badly?
93 Accord LX Sedan (sold)
but the thing is when I park at certain angles it looks fine but then again on flat surfaces the front end on that side is also setting up higher it is like an inch higher but when I took the wheel off to replace a stud I didnt notice anything diff but Im going to check the suspenion tower in the morning to se if that is messed up because the car runs fine just when gunning it the car wants to pull to the right and the obvious ride height on that side and the wheel sticking out
Start simple.
If the position of your wheels are off center or you're pulling towards the right/left while driving, get an alignment. Have the technician print you out the specs that were measure. Most likely, it sounds as if your tie-rod might have gone bad or it probably wasn't adjusted properly...hence, the toe in/toe out problem that you have.
You also mentioned that it sits a bit higher on one side. Did you ever consider perhaps a slight incline or decline of the ground that your car sits on?
