Power loss at 2500rpm
    My car has been off the road for a few months. Idles fine, drove fine for about 15 minutes... then the power died off at 2500rpm. It felt like a fuel cut, softly bucking and misfiring. It never stalled out, and it pulled strong under 2500. I drove home in 5th at 35mph.
    When I got home, I popped the hood. Sparkplug wires are alright (1 and 3 have damaged threads, and have caused problems before... not doing it tonight)
    I turned the car off, and then tried to restart. I got a click, and all went dead. This happens often, and is fixed by messing with the battery cables (they aren't conducting as they should... going to grease them tomorrow). The negative cable seems to be the main culprit.
    Now, loose/dirty cables have caused the car to cut off while running in the past. Could this possibly be my problem? I haven't driven it since I got it home, so I don't know if my tinkering fixed anything.
    Any other suggestions on what could cause this problem? It's been sitting, and was running perfectly fine before I pulled it off the road in January.
    For those that don't know my setup, it's a 94 JDM H22A. It's also currently overfilled and way overdue for an oil change... Doing that first thing once I get it inspected!
    are you getting any ecu codes? Maybe it's in limp mode, might want to check that out.
    Cars:
    91 Accord LX Sedan (sold)
    98 Accord LX Sedan
    95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
      maybe bad gas? you said its been sitting for months....it could have clogged some things..injectors/fuel filter etc.
      member's ride thread
      91 Accord SE 176k
        The negative cable is known to get corroded and cause the "click/hardstarting" problem on Cb's. Change it out. Or fab up a new one yourself.
        Can you get a pic of the plugs?
        Also did any dash lights come on when the problem occured?
        My 5.7 LS1 Holden Ute
          Ignition switch.....Mike..you know this all too well.
          check that Negative battery cable...is it corroded?
          CHANGE IT...
          but Id look into getting a new ignition switch AND cap/rotor ..
          but theres another thing tickling my mind.
          Fuel filter ( when was the last time you changed it? )
          but like EVIL DEMON said and what I would suggest FIRST. ( negative battery cable )
          do the simple things first Mike!
          keep us posted!
          92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
          MR Thread:
            I had that exact same problem deev. It was my battery cable terminals. They could not get tight enough around the battery posts. So once in a while I'd get no start and stalling. I ended making new cables and using these terminals.
            Also, I dont know about H22s, but on my A6 the green alt plugs came loose and caused all kinds of shit. I couldn't rev, bucking like crazy, backfiring, etc
              Originally posted by oozingmachismo2
              I had that exact same problem deev. It was my battery cable terminals. They could not get tight enough around the battery posts. So once in a while I'd get no start nad stalling. I ended making new cables and using these terminals.
              yeah..I remember that Eugene...speaking of...hows your CB coming along?
              got me a beater.
              I call it ( rustzilla )
              heres a few FAST pics..and then its back on topic.
              and the close..( BEWARE )..may scare you!
              but the rest of the car is ok. only has 155K.
              OFFTOPIC... Mike..let me get your rear quarters!
              ( strickly a work car )
              MR Thread:
                daayyyuuuuuummmm....Poor accord..fukking cancer..how $$? My cb is ok.needs tie rods, window put on track. thats it pretty much. Other than that running stronger than ever.New UCAs, radiator, hoses, Not a drop of oil leaks. I just looked underneath it yesterday and nothing is rusted underneath .....Unlike my Nissan
                Deev those terminals are like $3 a pop if you decide to use them.
                  the terminals..you can find em even cheaper...its called the Junkyard
                  PNP FTW
                  but yeah Mike...hope you get that booger running correctly.
                  MR Thread:
                    I put some conductive grease on the terminals, and cleaned them off... same crap is happening. I'll have to check the alternator plug... that's a new one to me.
                    I'm going to pull the spark plugs tomorrow, though I'm nervous to do so. 1 and 3 have damaged threads, and they're currently in there pretty good... I'm afraid I won't get them in tightly again!
                    I put fresh gas in it yesterday. I don't know if the old gas (only 3 months old) mixed in with it could be causing a problem. I've NEVER changed the fuel filter (I have one... just haven't put it on) so that may be it.
                    Tomorrow: check cap and rotor, replace plugs, sand cables and terminals, get the car inspected because my GTP has a major oil leak and the CB7 is once again my reliable car!
                      no EGR valve on this right deev?
                        i've heard of old gas causing gunk that clogs up fuel lines but i'm not sure how long it takes.
                          It's bone stock, so yeah, the EGR valve should still be there.
                          Maybe I'll try some injector cleaner as well. I know it's not great stuff, but hey... worth a shot!
                            another thing that comes to mine is a clogged cat... but i'm stumped, you feel pretty confident its the ignition system?
                              might as well try the seafoam treatment if you're gonna do that.
