My car has been off the road for a few months. Idles fine, drove fine for about 15 minutes... then the power died off at 2500rpm. It felt like a fuel cut, softly bucking and misfiring. It never stalled out, and it pulled strong under 2500. I drove home in 5th at 35mph.
When I got home, I popped the hood. Sparkplug wires are alright (1 and 3 have damaged threads, and have caused problems before... not doing it tonight)
I turned the car off, and then tried to restart. I got a click, and all went dead. This happens often, and is fixed by messing with the battery cables (they aren't conducting as they should... going to grease them tomorrow). The negative cable seems to be the main culprit.
Now, loose/dirty cables have caused the car to cut off while running in the past. Could this possibly be my problem? I haven't driven it since I got it home, so I don't know if my tinkering fixed anything.
Any other suggestions on what could cause this problem? It's been sitting, and was running perfectly fine before I pulled it off the road in January.
For those that don't know my setup, it's a 94 JDM H22A. It's also currently overfilled and way overdue for an oil change... Doing that first thing once I get it inspected!
