i have a 91 accord with a f22b1 vtec and i replaced all the gaskets about 2-3 months ago when i put the motor in, i now have a oil leak and i have looked and replaced every gasket except the head gasket. now my question is will the head gasket let oil leak or will it let coolant only. it is coming from between the head and the block and i cant tell if it is the head gasket. if you dont think it is what else could it be. tell me ideas and i will let you know if it has been replaced or not. thanks for the help!
head gasket problem?
come on man.....l.
if ya need help, be MORE SPECIFIC.
What side of motor? Left? Right? Front? Back? How much oil? What kind of oil are you using?(syn. or reg). Can you SEE the leak? WHEN does it leak.
Fill us in, and we'll fill u in.
But no. doesn't really sound like head gasket.
Noobie my ASS.
it is coming from the top part on the passenger side where the tranny meets the block but it is not my tranny because it leaks up above it and it leaks a little puddle everyday. usually leaks the most when it is hot and i am using valvoline 10-40 oil. it has gotten to the point where it is on the back of the block and on the drivers side. leaks everywhere but the front of the motor and it is not the valve cover gasket because that has been replaced and it is not the vtec solenoid or pressure sender because they to have been replaced so have any ideas now?
