stripped threads on f22 head, repairable?
    the stud on the exhaust side, closest to the water neck will no longer torque because the threads are stripped in the head. is this repairable with a heli-coil or any other thread repair methods?
    thanks
    You will need to re thread probably with a larger stud
    wat?
      heli coil f.t.m.f.w.!!
      some cars have wings cuz they look cool.
      some cars have wings cuz they increase efficiency.
      some cars have wings to keep them from taking flight.
      f1 fan
        should i try re-threading w/ a larger stud first, or go for the heli-coil?
          Try running a bigger size tap in there and then using a different size bolt.
            alright. so a bolt is ok, or should i run a stud still?
              id helicoil it just to be safe. after that you can still run the stud.
              I <3 G60.
                is there a torque spec for the manifold studs?
                  anyone know?
                  anyways, i heli-coiled the stripped threads and it worked mint. torqued down nice and tight, didn't take much to tap either
                    anyone know?
                    Sticky in the Beginners Section.
                    http://www.cb7tuner.com/vbb/showthread.php?t=55331
                    3 CB's gone....
                    1 WK Overland....
                    Still miss the CB though......maybe one day.
                      Originally posted by 91Accord-LX View Post
                      completely overlooked it the first time, thanks!
