Did some more testing.
Did some tests that my repair CD suggested. Here's what it said to do, and what I found.
Ignition coil power source- disconnect ignition coil primary leads. Turn ignition on. Using voltmeter, check voltage between ground and black/yellow wire terminal of ignition coil harness. Battery voltage should be present.
There are 2 wires on the harness, a thick yellow one, and a skinny black with yellow stripe. Battery voltage was present on the thick yellow one but not the skinny black/white one.
Igniter power source- Turn ignition off. Disconnect harness connector at distributor. Turn ignition on. Using voltmeter, check for battery voltage between ground and black/yellow wire between ignition and harness connector.
Now here is where I'm sorta confused. Which connector exactly do they mean? There are 2 connectors close by....one multi connector one, and one 2 prong connector. I tested both, and found voltage on the thicker wire of the 2 prong connector (forgot which color) and voltage, although 2 volts lower than battery voltage, on the yellow with green stripe wire on the multi connector.
Ignition coil resistance- Remove primary and secondary leads from ignition coil. Using an ohmmeter, check resistance between primary terminals A and C of ignition coil. Resistance should be .6 to .8 at room temperature.
Here is a pic of the terminals
click to see
http://pg.photos.yahoo.com/ph/mytoyo...PLMuBBKnRls0In
My meter beeped for continuity and read .01. So does this mean it is bad? I probed around and found .8 on some other terminals, but I don't know what that means.
Check resistance between terminals B and D of ignition coil (tach circuit). Resistance should be about 2090-2310 ohms at room temperature.
I got NOTHING.
Check secondary resistance between terminals A and secondary output terminal (coil tower). Resistance should be 14,400-21,600. Check for continuity between terminals A and B. Continuity should exist. If readings are not within specification, replace coil.
I got 18.32k. And had continuity.
So what does all this mean? Bad coil? I might go to AutoZone and test out a new one they have and see what specs I get.
click to see
I got NOTHING.
