4040 mounting position
    im ready for my NON abs conversion, but would like too know which way my 4040 valve mounts.
    the bracket has nothing too do with anything, i can change that around, but the real question remains.
    does "4040" face right side up where you can read it? Or does it mount where its upside down?
    just installed mine yesterday.....when the 40/40 was facing upside down the valve did not line up with the lines because of the position of the bracket....40/40 right side up and everything lines up.
    My Members Ride Thread
      cpmike said he had too remove the bracket though....
        yes u swap your bracket from your cb prop valve onto the 40/40 valve
          THE FINAL debate can we get a 100% YES or no answer for this timless question PLEASE
          F/S:Pioneer Premier Deh-880prs w/ ipod adapter $220
            im not an abs guy, but i thought the abs unit was my prob valve? its a 93 ex and i dont see a prop valve under the master cylinder.
              yea abs cars dont use a prop valve like non-abs
                thanks man, thought so.
                like i said before, the bracket is 100% irrelavant too my initial question....
                does "4040" face up or down?
                  4040 will read just like that>>>4040 facing up...i will takes pics of mine tomorrow if u like.
                    nope. thats all i need too know. i appreciate it man.
                      on second thought post them incase someone needs future refference.
                        I 2nd that also
                          any pics yet of the correct position??
