Sparkplug grommets and sparkplug lower tube seals
    ok, im a bit confused on this. I bought a valve cover gasket set at the dealership, this included the big valve cover gasket, and four smaller gaskets that were round. Where these the lower tube seals or grommets ?
    ive already changed this whole set and i still find oil in my sparkplug holes.
    MY CB7
    FULL part out thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=204494
    Upper SP seals
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      lower tube seals are thin o-rings not thicker grommet ones
        so in my valve cover gasket set, they gave me lower tube seals, right?
        MY CB7
          you tell us, did it come with the 4 extra tube seal orings or not?
            I also want to know if the H22 motor has lower spark plug tube seals or no?
            Sig removed due to excessive size
              no it does not.
                Thaks a lot Mike yo D man...
                  yeah, it had 4 o-ring things, im just trying to get the names correct.
                  what are the names of those?
                  MY CB7
                    you should have gotten...
                    one VC ghasket
                    4 upper seals ("O" in shape)
                    4 lower seals ("O" in shape)
                    93 Accord LX Sedan (sold)
                      hmm, i dont remember getting 9 gaskets total
                      there was only the valve cover gasket and 4 seals, im pretty sure
                      yeah...looking back at my reciept...there's only 5 gaskets,
                      but im not sure which set i didnt get
                      327079 QTY x 4 <<that's the one i have installed
                      what is the name of that one? upper or lower seal?
                      MY CB7
                        well the upper ones are made about as wide as the VC ghasket. while the lower ones are like a thin round rubber band
                          lol, i cant remember the thickness of it
                          MY CB7
                            look at the 4 same sized rings under the far right hole of the header gasket. those are the uppers
                              The upper seals are round but have a squarish cross section and have 3 notches as shown in the picture above. The lower tube seals are mote like o-rings and have a round cross section.
