my car keeps hesitating and sputtering when i accelerate from a stop. What should i check? Also my VSS is toast need a new one.
hesitating
remove the plugs and check to see if their soaked in oil.. thats a good source for the hesitation misfiring.. sensation you may be getting.. check the dizzy and all its components..
also.. my vss is bad and it makes the ecu run in limp mode adding more fuel than it should.. so its gonna make the problem even worse..
my bet is on the plugs being nie and wet.. or something ignition related..
my girls altima does the same damn thing.. damn spark plug O-rings
Praise The Lowered...
