Gasket for aftermarket Header?
    i just did my headgasket and i bought a stock gasket and it fit perfect with my Megan racing header. it'll fit no problem. If the OEM gasket dont fit your aftermarket header then it wont' be for your car.
    Originally posted by toycar
    Braking the bank, maybe. Feeling like a boss, likely.
      high temp silocone is great.
      miss my turbo cb7
        x2
        No need to waste money on an aftermarket exhaust gasket. The OEM multi Layer crush style gasket is all you need. If it doesn't fit then you need a new header. Just think about it for a minute.... OEM will work unless you have changed the ports on your head. Only way it wouldn't work is if the ports for the headers are wrong.
        MR Thread
        GhostAccord 2.4L Blog
        by Chappy, on Flickr
          Originally posted by GhostAccord
          x2
          No need to waste money on an aftermarket exhaust gasket. The OEM multi Layer crush style gasket is all you need. If it doesn't fit then you need a new header. Just think about it for a minute.... unless you have changed the ports on your head there is no reason that the OEM wouldn't work? Unless the headers are wrong.
          I'm pretty sure he is referring to the header/downpipe gasket, not the head/header gasket.
            no gasket in between the header and downpipe
              I had the same problem. I ended up buying a sheet of high temp gasket material and making my own. Summit sells it on ebay or you can buy it direct from Summit Racing. I seen not too long ago that they're selling the actual gasket on ebay for between the header/dp. I had a problem also finding a gasket for where it connects to the cat. I emailed everyone selling a header on ebay to see if they'd sell just the gasket but none of them would. I'll try to find a link for the copper dp gasket on ebay.
              Never underestimate a 4-door Accord
                Heres a whole set and then just the dp gasket:
                http://cgi.ebay.com/ebaymotors/Exhau...m350058940761&
                You're welcome
                  Oooops Missed that! Oh well maybe this is what he's looking for then. Yes it says headman but it will fit any 3 bolt y-Pipe with 1 5/8" primaries.
                  Summit part number: HED-27180
                  10 bucks and it's headman quality not Egay lead coated crap!
                  MR Thread
