I just changed my front rotors and my break pads, I put everything back together and tested it out, and now it seems like I have to mash the break pedal damn near to the floor for the car to stop, I sat in the car for 45mins just stepping on and off the breaks, it helped alot but it still doesnt fell as tight as it was. What could be the problem?
Brake Question
start in the rear...work your way up to the front
kinda like the opposite of wiping your butt
doesn't matter if you start with pass or driver side though
check resv. every two pumps...make sure you have the brake pedal held down when you release the bleeder valve...make sure to tighten the bleeder all the way back up before releasing the brake pedal____
just for the record it does matter what you bleed first, and you shoudl always bleed the enitire system regaredless,, start with the right rear , left rear ,front right, then front left, ,, always bleed starting with the furthest point from the master cylinder, and remember the brakes are split in a x formation front left and right rear brakes are on the same brake circuit and fron right and left rear are on the same circuit in comparison to the proportioning valve, so be sure u bleed all 4 when u have the lines open,,-95 JDM H22 LSD-
-HYTECH Header-
-Skunk2 IM-
Originally posted by BIGDOMjust for the record it does matter what you bleed first, and you shoudl always bleed the enitire system regaredless,, start with the right rear , left rear ,front right, then front left, ,, always bleed starting with the furthest point from the master cylinder, and remember the brakes are split in a x formation front left and right rear brakes are on the same brake circuit and fron right and left rear are on the same circuit in comparison to the proportioning valve, so be sure u bleed all 4 when u have the lines open,,
Anyway the way I did it last time when I changed my MC, which requires all lines bled, RR-> RF-> LR-> LFwat?
