how could i do this? i dont want to take the tank out just to find the fuel pump wires are good. so can i just jumper it? wheres the wires that run to it?
manually power the fuel pump
Originally posted by quickangel93how could i do this? i dont want to take the tank out just to find the fuel pump wires are good. so can i just jumper it? wheres the wires that run to it?
I dont remember exactly which pins, but you can bridge terminals at the main relay connector. You can also check the continuity there if you find the pins for the fuel pump
