USDM vs. JDM OBD1 H22 Injectors.
    Are there any differences? I got a 94 JDM h22a, and I need stock injectors for emissions. Not sure if the obd1 USDM ones are differnt from the obd1 JDM injectors.
    If anyone can shine a light please do. thank you.
    Originally posted by wed3k
    i rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
    The JDM ones are 345 cc/min rated, I believe the USDM may be a slightly smaller size? Please, someone correct me if I'm wrong. I know the connections will be the same to the stock harness.
      Supposedly the JDM ones are 345cc/min and the USDM ones were 315cc/min. Those are the numbers that float around in the prelude world anyways.
        Also, I can tell you when I had my JDM H22 injectors cleaned & flow tested, they actually put out 355 cc/min at industry standard 43.5 psi, every single one of them. Manufacturer was Keisho. So they are spot on and apparently under-rated.
          shit, i forgot what your accel ones flowed at.
            soo = h22a injectors are 345-355cc peak and hold injectors ..
            thank you guys much!
            ..seems like these are pretty hard to come by .. found one on ebay.. but looks like i got some bidding competition.
              Your looking for any USDM VTEC Prelude injector from 92-96 they are 345cc.
              They are $100 each for a new ones at the dealership....The one set of 345cc H22 injectors on ebay are well worth it to buy'em now @ $80.
              A set of 345cc injectors for $31 is a steel...heads up for anyone else looking for a set of cheap 345cc low impedance injectors Good luck
              MR Thread
              GhostAccord 2.4L Blog
              by Chappy, on Flickr
                ty my ebay = madcheesin .. do i call DIBS!!
                  ouch, at those prices youre almost better off going aftermarket
                    already got aftermarket.. but i need stock for emissions.
                      i see. i never have to worry bout emissions in sd
                        .. i got jacked.. lol. i went back to the ebay auction to buy it now.. and it was already bought now. . so now. what do you guys think of me buying just some oem relacements? i think they are like CVU brand injectors..like $37 each
                        heres a link:
                        http://www.car-stuff.com/carparts/ho...42-121191.html
                          not trying to thread jack but while we are on injectors this is the last step to my swap...
                          i got a h22a4 so the injectors are odb2 and what? 270cc?? i need the obd1 and have to run a resister... ok so do i use the one thats on the CB7 stock or do i need to use the one from the lude? also if i just change the clips and use the obd2 injectors i take the resistor out completely??? just cap off the wires????
                          will h23 injectors work in h22??
                          and what if i want to go after marker injectors?? i dont want to do anything to hurt the motor but even if i was to put a higher cc injector into the H wouldnt it all be determind by the fuel pressure reg????
                          Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
                          But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
                            someone help me out with the above post ^^^^
                              heres a link:
                              i just checked the accel boxes tonight and thye say 370cc's so we are def. over stock ones
